[Li...] Posted December 18, 2019 Share Posted December 18, 2019 #1 On an offline seat/simulation, how do I get access(to be able to choose from) to any and all stylus and stylus system on the various CMM's throughout the plant? #2 How long of a stylus stem can you put together on a VAST XXT TL3 head? There has to be a limit. Link to comment https://qualityforum.zeiss.com/topic/17000-2-part-question/ Share on other sites More sharing options...
[Ro...] Posted December 18, 2019 Share Posted December 18, 2019 #1 Go to your CMM's around the shop and open the probe tool box and "export" all the probes to a network location or flash drive, then when you get to your offline seat Import them in. If you want to make your offline seat a "Clone" of one of your CMM's, go to your CMM and go to EXTRAS>SETTINGS>MISCELLANEOUS and under the Maintenance tab Save a backup on a network drive. Then go to your offline seat and do the same thing but click Restore. Now your online seat will have all the same machine settings and whatnot including header files and probe racks. #2 Note: following information can be trusted 100% , because i got it on the internet. 65MM seems short, but that's what the internet says.fgjhkfgdjhkfgdjhkfgd.JPGfgdjhkfgdjhkfgdjhkfgd.JPGfghjkghjkfghjk.JPG Link to comment https://qualityforum.zeiss.com/topic/17000-2-part-question/#findComment-95096 Share on other sites More sharing options...
[To...] Posted December 18, 2019 Share Posted December 18, 2019 Please sign in to view this quote. 150mm Link to comment https://qualityforum.zeiss.com/topic/17000-2-part-question/#findComment-95098 Share on other sites More sharing options...
[Th...] Posted December 18, 2019 Share Posted December 18, 2019 Spec sheet for the XXT says 30-150mm with a max weight of 15 grams. Link to comment https://qualityforum.zeiss.com/topic/17000-2-part-question/#findComment-95100 Share on other sites More sharing options...
[To...] Posted December 19, 2019 Share Posted December 19, 2019 Please sign in to view this quote. Roberto, where did you get that page on the XXT sensor? It's full of bogus info. Link to comment https://qualityforum.zeiss.com/topic/17000-2-part-question/#findComment-95102 Share on other sites More sharing options...
[Li...] Posted December 19, 2019 Author Share Posted December 19, 2019 Thanks for the info gentleman. I'm going use a flash drive to pull the stylus info and save it to my offline. Right now I am building stylus for a system that is 166mmx5mm. All the angles I have done so far are giving pretty good "S:" values. I think the highest was .0004 Link to comment https://qualityforum.zeiss.com/topic/17000-2-part-question/#findComment-95104 Share on other sites More sharing options...
[Ro...] Posted December 19, 2019 Share Posted December 19, 2019 Please sign in to view this quote. Google "VAST XXT TL3" and its the 5th search item down for me. Its a page from ThimasNet Dot Comfgdjhfgdjhkfgdjhk.JPG Link to comment https://qualityforum.zeiss.com/topic/17000-2-part-question/#findComment-95106 Share on other sites More sharing options...
