copying features with offsets
Another possible solution.
If you have a partial cad model that maybe is a piece of a much larger assembly, or for whatever reason does not contain as many "things" as you need, you could first make a copy of your cad model, then load the copy in and use CAD>MODIFY CAD ENTITIES to delete everything but the thing you are trying to duplicate and use CAD<CAD FILE<SAVE to save that bit. Then you can load as many of the new things in as you need and just use the transform to put them where you need them.
Pictured
I deleted everything but the outer skin of a model i was working on, then saved it and re uploaded it into my program and spaced them into a 1 inch square. whole process took about 5 minutes.
