[Ri...] Posted December 18, 2019 Share Posted December 18, 2019 I have part that requires a secondary alignment to pull points in the correct vector direction. It's basically my base alignment rotated -15° about Z. When i create the second alignment I am selecting all the same features that my Base Alignment used and using Special -15°. The problem with this is that it now has to remeasure all those features to create this new base alignment, despite the fact that they having already been measured for the Base. Is there a way I can use the already measured Base Alignment features for my new alignment so that it don't have to measure twice? thx Link to comment https://qualityforum.zeiss.com/topic/17010-secondary-alignment-question/ Share on other sites More sharing options...
[Ad...] Posted December 18, 2019 Share Posted December 18, 2019 If I'm understanding that you want to rotate a previous alignment by 15 degrees in the same measurement plan you just need to create an alignment 1) Select Resources 2) Select Untilities 3) Select Alignment 4) Using pull down tab select the alignment you want to rotate (in this case Base Alignment) 5) Select Special 6) Select Rotate by an angle 7) Select axis and enter angle you need to rotate 8) Click OK and close the Alignment window This won't require the features to be probed a second time Link to comment https://qualityforum.zeiss.com/topic/17010-secondary-alignment-question/#findComment-95160 Share on other sites More sharing options...
[Mi...] Posted December 18, 2019 Share Posted December 18, 2019 I believe if you just leave the boxes blank in the secondary alignment editor, it will reuse existing values from the base alignment. Link to comment https://qualityforum.zeiss.com/topic/17010-secondary-alignment-question/#findComment-95162 Share on other sites More sharing options...
[Th...] Posted December 18, 2019 Share Posted December 18, 2019 Strange that it would be probing the alignment features again, I use base alignment features in secondaries for simple rotation a LOT and Calypso just recalls the existing data. Are you defining new features on the same surfaces? In this case, though, if all you're doing is rotating the base alignment then both Adam and Michael are right. Link to comment https://qualityforum.zeiss.com/topic/17010-secondary-alignment-question/#findComment-95164 Share on other sites More sharing options...
[Ri...] Posted December 18, 2019 Author Share Posted December 18, 2019 Please sign in to view this quote. 4) Using pull down tab select the alignment you want to rotate (in this case Base Alignment) This is the magic sauce I was missing! I was selecting all five elements again in the new alignment, which makes sense that it was then reprobing them all. I didn't realize there was a pull down to reselect my previously defined alignments which I could then special. Thank you! Link to comment https://qualityforum.zeiss.com/topic/17010-secondary-alignment-question/#findComment-95166 Share on other sites More sharing options...
[Ia...] Posted December 18, 2019 Share Posted December 18, 2019 Please sign in to view this quote. I still don't think that should be happening. Link to comment https://qualityforum.zeiss.com/topic/17010-secondary-alignment-question/#findComment-95168 Share on other sites More sharing options...
[Ro...] Posted December 18, 2019 Share Posted December 18, 2019 Are you using "Use Current" for your alignment? If so then your alignment is not being taken at the start of the program. Link to comment https://qualityforum.zeiss.com/topic/17010-secondary-alignment-question/#findComment-95170 Share on other sites More sharing options...
[An...] Posted December 19, 2019 Share Posted December 19, 2019 Please sign in to view this quote. Using pull down tab select the alignment you want to rotate (in this case Base Alignment). Link to comment https://qualityforum.zeiss.com/topic/17010-secondary-alignment-question/#findComment-95172 Share on other sites More sharing options...
