PCM SYNTAX
Good luck with that.
I don't know if there is a "master List" of commands, and as you mentioned when you click on a command from th parameter list and it plops into the box, its often so far off from a useable command, and its only thru very tedious trial & err that we (programmers) can get a new command to work.
And if you were to make the egregious err of typing GetActual instead of getActual the command won't work, and worse off nothing will pop up and say "The G, it should not be capital".
What are you looking to do?
https://qualityforum.zeiss.com/topic/17042-pcm-syntax/#findComment-95320
