[SH...] Posted December 4, 2019 Share Posted December 4, 2019 Is there is any option to save my calibration result??IMG20191204064857.jpg Link to comment https://qualityforum.zeiss.com/topic/17124-saving-calibration-result/ Share on other sites More sharing options...
[Ün...] Posted December 4, 2019 Share Posted December 4, 2019 This way you can save Probing system qualification > Stylus system management > stylus Link to comment https://qualityforum.zeiss.com/topic/17124-saving-calibration-result/#findComment-95806 Share on other sites More sharing options...
[Cl...] Posted December 4, 2019 Share Posted December 4, 2019 You can use a result element with a formula to achieve the same end result. Link to comment https://qualityforum.zeiss.com/topic/17124-saving-calibration-result/#findComment-95808 Share on other sites More sharing options...
[SH...] Posted December 4, 2019 Author Share Posted December 4, 2019 Please sign in to view this quote. May I know what is 1, y+ ,SCA stands for?. Actually I am using a vast XT probe,not RDS my probe head does not rotate.1stands for probe number, y+ is the direction??. For probe, number 3,4,5 should I use same number?? what about direction??. Link to comment https://qualityforum.zeiss.com/topic/17124-saving-calibration-result/#findComment-95810 Share on other sites More sharing options...
[Th...] Posted December 4, 2019 Share Posted December 4, 2019 Those are just the names he has assigned to his specific setup. The generic format is getProbe("stylus-name","stylus-system-name").characteristic. Link to comment https://qualityforum.zeiss.com/topic/17124-saving-calibration-result/#findComment-95812 Share on other sites More sharing options...
[Cl...] Posted December 4, 2019 Share Posted December 4, 2019 SCA (stylus configuration "A") With one of three probes being a 1.0mm stylus facing Y+ Link to comment https://qualityforum.zeiss.com/topic/17124-saving-calibration-result/#findComment-95814 Share on other sites More sharing options...
[Ro...] Posted December 4, 2019 Share Posted December 4, 2019 This is only for Probe Qualification Program. Go to Resources > Name output files > for this program elect "Default Printout" from the dropdown menu Check "Name output files variable" Copy--------------------> "C:\Temp\Zeiss_Qual\"+"Zeiss Calypso "+getRecordHead("planid")+" "+getRecordHead("date")+" "+getRecordHead("time")+".txt" That will create a pdf copy in your C/Temp folder under sub folder "Zeiss Calypso" you can edit it for your own needs. Ok That should be it. I dont think you need to Initialize, but if it doesnt work Go to Resources > Results to file and click on the "initialize" buttonmhgvkhvhv.JPGfdjhksfdjhksfdjhksfd.JPG Link to comment https://qualityforum.zeiss.com/topic/17124-saving-calibration-result/#findComment-95816 Share on other sites More sharing options...
[Te...] Posted December 6, 2019 Share Posted December 6, 2019 If you go to Multiple Report in the Measurement tab and turn on Multiple printout if it is not on. Add the default printout to the list and send it to pdf or text and you have saved the result in the default printout format. If you want to get fancier and send the report to an SPC package like QC Calc you have to generate characteristic in the report like discussed in previous post. I will attach my Probe qualification guide that will help explain the result element and the "formula".Probe Qualification Program 2018.pdf Link to comment https://qualityforum.zeiss.com/topic/17124-saving-calibration-result/#findComment-95818 Share on other sites More sharing options...
[SH...] Posted December 6, 2019 Author Share Posted December 6, 2019 Please sign in to view this quote. Waw that is deep indeed.......🤗🤗🤗 Link to comment https://qualityforum.zeiss.com/topic/17124-saving-calibration-result/#findComment-95820 Share on other sites More sharing options...
