[Me...] Posted May 30, 2019 Share Posted May 30, 2019 hi can any one explain how to offset a point before alignment ... or is there any direct option called offset point Link to comment https://qualityforum.zeiss.com/topic/17148-regarding-point-offset-before-alignment/ Share on other sites More sharing options...
[In...] Posted September 17, 2019 Share Posted September 17, 2019 You can offset a 'Plane' by using 'Plane with Offset' under 'Construction'. If you wish to use the offset plane for alignment. Or In "Base Alignment > Special > Offset" option is there. But if it's "Point" i.e. only one point on a surface; i don't think you could offset it. Link to comment https://qualityforum.zeiss.com/topic/17148-regarding-point-offset-before-alignment/#findComment-95954 Share on other sites More sharing options...
[No...] Posted September 18, 2019 Share Posted September 18, 2019 You can, if you recall it to a second point and modify the recall formula (add offset). Link to comment https://qualityforum.zeiss.com/topic/17148-regarding-point-offset-before-alignment/#findComment-95956 Share on other sites More sharing options...
[In...] Posted September 18, 2019 Share Posted September 18, 2019 Please sign in to view this quote. Can u plz put the steps? something like "Construction > Option X > Option Y etc.. I would like to try this out 🙂 Link to comment https://qualityforum.zeiss.com/topic/17148-regarding-point-offset-before-alignment/#findComment-95958 Share on other sites More sharing options...
[No...] Posted September 19, 2019 Share Posted September 19, 2019 It's quite simple: - Define a point with nominal values as usual. - Define another point by selecting from the menu - In the second point, select to recall a single feature and select the first point to be recalled - Make sure the selected alignment is the same as for the first point - All the fields of the second point are filled with formulas (yellow) - Let's say you want to offset the point in +Z - Right klick the nominal Z field and select formula - In the formula editor you see the the existing formula that was put there by the recall function, something like: getActual("Point1").z - Add your offset at the end of the formula: getActual("Point1").z + 1.234 Link to comment https://qualityforum.zeiss.com/topic/17148-regarding-point-offset-before-alignment/#findComment-95960 Share on other sites More sharing options...
[In...] Posted September 19, 2019 Share Posted September 19, 2019 Thank you, Will try it 1st thing in the morning. 😃 Link to comment https://qualityforum.zeiss.com/topic/17148-regarding-point-offset-before-alignment/#findComment-95962 Share on other sites More sharing options...
[Me...] Posted November 21, 2019 Author Share Posted November 21, 2019 I have a similar issue. I am new to Calypso and I have four datum targets that need leveled. I have the original/first point then the second point recalled to single feature and the formula is set to offset point A2, A3, and A4. I run the Base/Manual alignment but when I go to run the Start/Auto alignment the machine doesn't measure A2, A3, and A4. I followed the instructions, to my understanding, but I can not figure out how to get the Auto alignment to measure those three datums. Any help/advice would be appreciated. Thanks Link to comment https://qualityforum.zeiss.com/topic/17148-regarding-point-offset-before-alignment/#findComment-95964 Share on other sites More sharing options...
[Ia...] Posted November 21, 2019 Share Posted November 21, 2019 Please sign in to view this quote. What feature are you using for your base alignment? Did you recall all of those points into a plane? Link to comment https://qualityforum.zeiss.com/topic/17148-regarding-point-offset-before-alignment/#findComment-95966 Share on other sites More sharing options...
[Me...] Posted November 21, 2019 Author Share Posted November 21, 2019 A1 is the original point, A2, A3, and A4 are the offsets. I recalled A1 and the offsets for A2, A3, and A4. I am suppose to recall all the points including the original A1 thru A4 plus the three offsets? Thanks Link to comment https://qualityforum.zeiss.com/topic/17148-regarding-point-offset-before-alignment/#findComment-95968 Share on other sites More sharing options...
[Me...] Posted November 21, 2019 Author Share Posted November 21, 2019 The feature is a plane - Option - Recall. Link to comment https://qualityforum.zeiss.com/topic/17148-regarding-point-offset-before-alignment/#findComment-95970 Share on other sites More sharing options...
[Ia...] Posted November 21, 2019 Share Posted November 21, 2019 Instead of using Recall, use "recall feature points". https://www.ellisontechnologies.com/sit ... y_mode.pdf ^More information on different types of recall^ Link to comment https://qualityforum.zeiss.com/topic/17148-regarding-point-offset-before-alignment/#findComment-95972 Share on other sites More sharing options...
[Me...] Posted November 21, 2019 Author Share Posted November 21, 2019 When I use Recall Feature Points it doesn't give me the option to recall the offset points because they are Theoretical. Link to comment https://qualityforum.zeiss.com/topic/17148-regarding-point-offset-before-alignment/#findComment-95974 Share on other sites More sharing options...
[Ia...] Posted November 21, 2019 Share Posted November 21, 2019 Crap, that makes sense. My bad. Can you post snippets of the features and the formula you are using? Link to comment https://qualityforum.zeiss.com/topic/17148-regarding-point-offset-before-alignment/#findComment-95976 Share on other sites More sharing options...
[Me...] Posted November 21, 2019 Author Share Posted November 21, 2019 Link to comment https://qualityforum.zeiss.com/topic/17148-regarding-point-offset-before-alignment/#findComment-95978 Share on other sites More sharing options...
[Me...] Posted November 21, 2019 Author Share Posted November 21, 2019 I know what I want it to do, but I don't know the process or procedure. I have four datum targets for Datum A. I want to offset A2, A3 and A4 to A1. I created the plane with A1 and A2 offset, A3 offset, and A4 offset. But when I run the Auto Alignment it doesn't measure A2, A3, or A4 so the offset isn't being calculated. The alignment plane looks clocked instead of leveled or flat to the CAD. Link to comment https://qualityforum.zeiss.com/topic/17148-regarding-point-offset-before-alignment/#findComment-95980 Share on other sites More sharing options...
[Ke...] Posted November 21, 2019 Share Posted November 21, 2019 Did you try using the User Guide for "Offset Plane special geometry"? Link to comment https://qualityforum.zeiss.com/topic/17148-regarding-point-offset-before-alignment/#findComment-95982 Share on other sites More sharing options...
[Me...] Posted November 22, 2019 Author Share Posted November 22, 2019 From my understanding Offset plane only works with three points. I have four datum targets I am trying to level. Link to comment https://qualityforum.zeiss.com/topic/17148-regarding-point-offset-before-alignment/#findComment-95984 Share on other sites More sharing options...
[Ia...] Posted November 22, 2019 Share Posted November 22, 2019 Have you tried not using the offset plane in your base alignment, but just using it for the characteristic's datum structure? Or a separate alignment? I've had issues using features tied to other features for the base alignment. Link to comment https://qualityforum.zeiss.com/topic/17148-regarding-point-offset-before-alignment/#findComment-95986 Share on other sites More sharing options...
[Da...] Posted November 23, 2019 Share Posted November 23, 2019 Ashok Vardhana and Tristan Helton, similar or the same as Norbert described, but with screenshots: Repeat those steps for every point, you wish to offset. Note that the Nominal X,Y and Z filled with formulas will only do the graphical presentation, so you could see better what you are doing. The important one is "Z - actual" one. Link to comment https://qualityforum.zeiss.com/topic/17148-regarding-point-offset-before-alignment/#findComment-95988 Share on other sites More sharing options...
[Me...] Posted December 3, 2019 Author Share Posted December 3, 2019 Dane, The pictures you attached are not working for me, they do not display. I got it to work, but the weird thing is I didn't change my method or process. I am not sure what happened but it did finally work as intended. Live and you learn. Thanks again to everyone who responded. Link to comment https://qualityforum.zeiss.com/topic/17148-regarding-point-offset-before-alignment/#findComment-95990 Share on other sites More sharing options...
[No...] Posted December 4, 2019 Share Posted December 4, 2019 Please sign in to view this quote. Welcome to the club 🤣 By the way, some (all?) of the old pic attachments went to the bin when they updated the forum software on Nov 22nd. Link to comment https://qualityforum.zeiss.com/topic/17148-regarding-point-offset-before-alignment/#findComment-95992 Share on other sites More sharing options...
