How to Alignment DRF Slot?
Well, my input is :
I would use A for Spatial, and X origin. and measure 2 slot planes, and create symmetry B and use for Y axis and planar rotation .
This seems to be missing a Z origin, although it's not needed for the position shown. ( you could use top or bottom of part, etc.)
Yes, Datum A constrains 4 degrees of freedom here. 2 degrees of rotation(this will be taken care of by your spacial rotation). and 2 degrees of translation(X AND Y origin). The only thing left for -B- is the planar rotation and Origin in Z. (B cannot actually constrain a degree of freedom in the Z direction though.)
