[Me...] Posted October 29, 2019 Share Posted October 29, 2019 Hello all, I have a question. Each inspection characteristic can be displayed in Piweb. What about PCM parameters? I have registered the OFFSET of a curve as parameter on the PLOT after old evaluation. The parameter OFFSET is available in CALYPSO PCM. But how does it behave when I evaluate with PiWeb, because OFFSET is not a inspection characteristic? What can I do ? Should I work with a formula in result element under inspection characteristic? Link to comment https://qualityforum.zeiss.com/topic/17388-pcm-parameters-and-piweb/ Share on other sites More sharing options...
[Kl...] Posted October 30, 2019 Share Posted October 30, 2019 Hallo Winfried, you gaven the answer yourself. Gruss Klaus Link to comment https://qualityforum.zeiss.com/topic/17388-pcm-parameters-and-piweb/#findComment-97446 Share on other sites More sharing options...
