[Mi...] Posted October 29, 2019 Share Posted October 29, 2019 Well I got 5x 4 mm IDs holes that are machined into a cylinder. I measure the Z heights of each circle and they can not vary more than 0.02 from each other. Guess you could call it a mutual offset. I am using Max feature for this. Just asking to make sure that I am on the right path as I have never used this feature in Calypso. Link to comment https://qualityforum.zeiss.com/topic/17390-circle-issues/ Share on other sites More sharing options...
[Da...] Posted October 29, 2019 Share Posted October 29, 2019 If there is a chance it could go in minus on axis, you would want to use result element and abs(). But can't give you example by heart and I am far away from Calypso. Link to comment https://qualityforum.zeiss.com/topic/17390-circle-issues/#findComment-97450 Share on other sites More sharing options...
[Mi...] Posted October 29, 2019 Author Share Posted October 29, 2019 Yeah it could go on either side of the 0.02 mm Link to comment https://qualityforum.zeiss.com/topic/17390-circle-issues/#findComment-97452 Share on other sites More sharing options...
[Mi...] Posted October 29, 2019 Share Posted October 29, 2019 Please sign in to view this quote. I would try measuring distance to each one from some other plane. Create a Maximum and Minimum feature, then use a Result Element characteristic to report the difference of these two. The nominal for the Result Element would be 0, and the max tolerance would be 0.02 Link to comment https://qualityforum.zeiss.com/topic/17390-circle-issues/#findComment-97454 Share on other sites More sharing options...
