[Mi...] Posted October 29, 2019 Share Posted October 29, 2019 Well I got 5x 4 mm IDs holes that are machined into a cylinder. I measure the Z heights of each circle and they can not vary more than 0.02 from each other. Guess you could call it a mutual offset. I am using Max feature for this. Just asking to make sure that I am on the right path as I have never used this feature in Calypso. Link to comment Share on other sites More sharing options...
[Da...] Posted October 29, 2019 Share Posted October 29, 2019 If there is a chance it could go in minus on axis, you would want to use result element and abs(). But can't give you example by heart and I am far away from Calypso. Link to comment Share on other sites More sharing options...
[Mi...] Posted October 29, 2019 Author Share Posted October 29, 2019 Yeah it could go on either side of the 0.02 mm Link to comment Share on other sites More sharing options...
[Mi...] Posted October 29, 2019 Share Posted October 29, 2019 Please sign in to view this quote. I would try measuring distance to each one from some other plane. Create a Maximum and Minimum feature, then use a Result Element characteristic to report the difference of these two. The nominal for the Result Element would be 0, and the max tolerance would be 0.02 Link to comment Share on other sites More sharing options...
