CAD Evaluation in Calypso 2019
We recently installed the latest version of Calypso on one of our Contura CMMs testing the water before we upgrade our other CMMs. Only snag we have so far is using CAD Evaluations if I select Characteristics in the Characteristics tab in the Evaluation window it will no longer display any results regardless of options checked (Actual,Nominal,Identifier....) If I select feature banners instead it works. There are a lot of programs we regularly use with CAD presentations saved that use Characteristics so I'd like to resolve the issue if possible rather than create new presentations for each program.
Hmm... Interesting. I've been using 2019 since it was released with no issues in the CAD Evaluation portion of it.
Have you tested to see if it is a legacy program issue, or if it occurs with new programs as well?
These parts are all under controls so I can't share them. I did contact Zeiss and have received a service pack that will hopefully address the problem.
  • 2 weeks later...
Yes I checked display.
Final word from Zeiss is there was a software change in 2019 version that prevents any masked features from being able to display in a CAD Presentation. Downside is now I need to modify a lot of programs over a change that is trivial to me.
