Precision Ceramic Cylinder
Thanks Norbert. I found the same website. We're looking for a local supplier here in the US but would consider going outside US if only option. Due to the size, ceramic is a much lighter and easier to handle option. Obviously, more stable from a temperature point of view.
I've seen them used to tram in lathe axis but, would work for anything I suppose.
In my experience, a ceramic square is generally used on milling type of machinery but, I could see using both too.
