True position to an axis.
Hi all,
I have a true position dimension with the datum structure being an axis between two circles. |TP|Ø0.010|R-X|
I create the TP characteristic just as on the print but I don't get an answer or i get zero as an answer. The feature in question is on the theoretical same axis as the datum. Am I getting zero simply because with the datum structure can run along the same axis infinitely until it fits perfectly on the circle?
I get variation in the feature X and Z position so I know its not really perfect. I need an explanation to bring to the engineer if it is linked to my assumption.
Thanks,
JG
https://qualityforum.zeiss.com/topic/17456-true-position-to-an-axis/
