NOt Updating Realistic Nominal size
Good Morning,
Recently I was asked a question as to why the CMM printout shows 4 Radii being checked as being exactly .135 r without any deviation throughout a significant period of the run. Actually all of the run. +
An endmill is interpolating this feature, I sincerly doubt this feature is being checked perfect 100% all the time.
Any ideas as to how to double check this? We've used point and scans to check the radius and called out the Ø (.270)
All are perfect?!!??!?
Do you have constraints on those radii features?
Have you tried taking single points without having the CAD feature selected? (Manually creating a new feature?)
We're taking single points and scanning. We also had the y constraint on and off but we keep seeing our .135 R
reporting @ .135.
Also this program is not using a CAD model
To further clarify this question.. It is possible to have constraints at the FEATURE and/or CHARACTERISTIC level. It is also possible to be rounding at 3 decimal places..
Apparently my co-worker found that the actual s weren't being reported when the Radius box was checked.
Any anyone tell me What is the purpose of this Radius box?
2040_18218e089e6d0984ec67747c6ff39512.docx
That is a size constraint. The purpose is to more accurately read location values, by constraining the size to nominal. If you only care about the size, you could constrain the x,y, and/or z.
Ok so to read true position in the best possible manner considering its a small radius, the R box should be checked.
Also if this feature is in my XZ i should constrain in Y. In my mind constraining would keep my probe readings in the XZ
"plane" without deviation in the Y axis to calculate a more stable reading?
