[Gö...] Posted October 11, 2019 Share Posted October 11, 2019 is it possible to measure this profile? GEAR PRO 123.JPGFetching info... Link to comment Share on other sites More sharing options...
[Ch...] Posted October 11, 2019 Share Posted October 11, 2019 Wow, Interesting. My question is : Is there an actual profile tolerance or gear ( or spline) data block for this ? Try it in gear pro, if you have all the other dimension, DP, major, minor, etc.. It looks GP has a 60° max pressure angle limit. Link to comment Share on other sites More sharing options...
[Gö...] Posted October 12, 2019 Author Share Posted October 12, 2019 the technical drawing of the relevant part is attached. thank you in advance for your help. 122.JPGFetching info... Link to comment Share on other sites More sharing options...
[Ün...] Posted October 12, 2019 Share Posted October 12, 2019 Please sign in to view this quote. Gökhan, A ve B detaylarını Gear Proda ölçebilirsin. Z detayını Contur ölçen cihazlarda daha kolay ölçebilirsin. Link to comment Share on other sites More sharing options...
[Ch...] Posted October 12, 2019 Share Posted October 12, 2019 I agree, you can measure A & B with Gear Pro, and I'm still not sure what the "Z" view is showing. It appears to be looking at the top land of the external tooth. If this is the case, yes you will have to do this in Calypso, line up a tooth, and measure planes, and/or lines. I think its about time Gear Pro allows for chamfering measuring, hey should least allow for chamfer input for Gear model, to know to avoid lead over travel, etc. I'll request it... Well, good luck! Link to comment Share on other sites More sharing options...
