renaming files without using Save As
As Henrik Lindahl said, in the inspection plan folder there is a file named "username". It simply contains the name of the inspection plan. Open with any text editor and change the name to whatever you want.
Depending on your naming convention, you may also want to change the name of the base alignment.
At least that's how I have done it.
