[Ro...] Posted October 10, 2019 Share Posted October 10, 2019 I forget..... how do you change the name of a file without opening it and using save as? I know that changing the folder name does nothing. Link to comment Share on other sites More sharing options...
[He...] Posted October 10, 2019 Share Posted October 10, 2019 It is in the file called username in the inspection plan folder. Link to comment Share on other sites More sharing options...
[Ia...] Posted October 11, 2019 Share Posted October 11, 2019 I've only ever done this by using Save as. Would anyone mind posting a quick tutorial? The save as way seems barbaric. Link to comment Share on other sites More sharing options...
[Ga...] Posted October 11, 2019 Share Posted October 11, 2019 As Henrik Lindahl said, in the inspection plan folder there is a file named "username". It simply contains the name of the inspection plan. Open with any text editor and change the name to whatever you want. Depending on your naming convention, you may also want to change the name of the base alignment. At least that's how I have done it. Link to comment Share on other sites More sharing options...
