Intersecting a curve.
Just want some back up on this...
I am creating an intersection of a plane and a curve. That intersection is at the ACTUAL intersection of the ACTUAL curve and the theoretical plane that I created, Right ?
If I make an intersection of a plane and a circle, the intersection is at the point where the actual, averaged ,perfect circle feature intersects with the plane ?
The circle that I am using has a very High form error. It is not matching to readings from some other equipment that we're using.
https://qualityforum.zeiss.com/topic/17532-intersecting-a-curve/
