Bad scan??
Below is a snip of a scanned ID. I can't explain what's going on with the points gathered. Everything looks normal during the run itself. The probe isn't touching anything but the (clean) ID, but that's not what the points show. I use this probe for several other features, and there are no problems with anything else. There are a series of ID's all at a similar height, and they all look like this...
Thoughts/ideas?
Dirty scales? Faulty probe head?
https://qualityforum.zeiss.com/topic/17582-bad-scan/
There are 10 diameters, of various sizes and heights, but all oriented left to right.
They all look similar.
I feel like an idiot child having to ask, but how hard do I shake it? I shut it all down, took the XXT off, and shook it a bit harder than I'd shake a bottle of OJ. I didn't heard anything.
https://qualityforum.zeiss.com/topic/17582-bad-scan/#findComment-98602
Lol. No worries, I doubt anyone has ever told you to do this! I have found that these plates can get stuck in the spring mechanism, so a little shake may not produce a rattle if that is the case. Otherwise, a slight shake should produce a rattle, which is the tell tale sign. If still unsure, you can actually see these plates if you look inside the end of the XXT.
https://qualityforum.zeiss.com/topic/17582-bad-scan/#findComment-98604
Move the sensor by placing it near your ear and if you hear something inside the sensor then very surely you will be damaged by an insurance or retainer of the restraint system, this type of sensors already in two occasions have given me that problem of damaging that suspension system by say it in a way
https://qualityforum.zeiss.com/topic/17582-bad-scan/#findComment-98612
I check a ring gage, with the same probe, and in the same orientation as the feature, yesterday. The ring looked gorgeous. Another detail is that the "bad" spots are always at the top of the scans. I can rotate the part and/or the probe, and the "bad" spots are always at the top.
Also, today, the machine is fumbling probe changes. Smaller (lighter) probes aren't staying in the probe rack, the magnetic head is pulling them forward, out of the rack when it drives away.
A coworker (unhelpfully) suggested the CMM could be on a ley line...
https://qualityforum.zeiss.com/topic/17582-bad-scan/#findComment-98626
Has the CMM been crashed? Or depending on your set up, one of the length or segmented measurement systems been compromised? Sometimes the segmented measurement systems are strips that are easily accessible. And little things such as cleaning, etc can even compromise them. Leaving you still able to calibrate and run parts correctly, but those areas compromised could cause trouble in various ways depending on how bad it is.
https://qualityforum.zeiss.com/topic/17582-bad-scan/#findComment-98634
