[Su...] Posted September 29, 2019 Share Posted September 29, 2019 When I was run a program circle about 4 mm dia checked 1 time in CNC run. But sometimes it's checked 2 or 3 times. I don't know why it's happening like that. Somewhere I heard one option "Loop" feature. But I don't know how to use and how to assign that option for the feature. Can anyone help to know about that option or why it's happening like that. Thanks in advance Link to comment https://qualityforum.zeiss.com/topic/17642-maybe-loop-option/ Share on other sites More sharing options...
[SH...] Posted September 29, 2019 Share Posted September 29, 2019 Please sign in to view this quote. The word sometimes makes me a wonder, if it 2,3 time it should always check two three times.first you verify inside the strategy window how many points whether it's for one circle or for two three circle. Loops are usually used for iterative alignment..... Link to comment https://qualityforum.zeiss.com/topic/17642-maybe-loop-option/#findComment-98966 Share on other sites More sharing options...
[Er...] Posted September 29, 2019 Share Posted September 29, 2019 I guess you have a passive sensor? If the sensor detects that it is measuring in the air. It will adjust and measure again. This can be tuned off, but why do that? If you dont have a passive sensor, your best bet is some kind of condition. And loops are used for more then iterative alignments. Patterns, loops. Autorun, loops. Etc............. Link to comment https://qualityforum.zeiss.com/topic/17642-maybe-loop-option/#findComment-98968 Share on other sites More sharing options...
