[SH...] Posted September 27, 2019 Share Posted September 27, 2019 The cycles time status Windows shows two times, one the actual time and other one I can't understand what is it. It is my setting time or something else , could you help me???IMG20190926081646.jpg Link to comment https://qualityforum.zeiss.com/topic/17648-cycle-time-status-window/ Share on other sites More sharing options...
[Da...] Posted September 27, 2019 Share Posted September 27, 2019 Upper should be "last run" and lower average from all runs (of this measurement plan?) Link to comment https://qualityforum.zeiss.com/topic/17648-cycle-time-status-window/#findComment-98982 Share on other sites More sharing options...
[SH...] Posted September 27, 2019 Author Share Posted September 27, 2019 Please sign in to view this quote. usually I run this program around 35 minutes but the average value shows 7 minutes, difficult to digest..... Link to comment https://qualityforum.zeiss.com/topic/17648-cycle-time-status-window/#findComment-98984 Share on other sites More sharing options...
[De...] Posted September 27, 2019 Share Posted September 27, 2019 Most likely this is either due to re-running the points, or re-running only a portion of the program which effectively adds a run with a close to zero run time. This throws off the average. I have not used it but I suspect this is what the checkbox is for which says "Do not record". If you check that it will likely not include the result into the overall result. Personally I just wish I could make that window go away and never come back, it is always wrong and it is frequently popping on screen over top of something I actually care about. Link to comment https://qualityforum.zeiss.com/topic/17648-cycle-time-status-window/#findComment-98986 Share on other sites More sharing options...
[Ia...] Posted September 27, 2019 Share Posted September 27, 2019 Please sign in to view this quote. Preach. Link to comment https://qualityforum.zeiss.com/topic/17648-cycle-time-status-window/#findComment-98988 Share on other sites More sharing options...
[SH...] Posted September 27, 2019 Author Share Posted September 27, 2019 Please sign in to view this quote. I got the point now, actually I have a long program, inside that I have three subprogram (one for true position, linear dimension and maching only). My customer asks me separate report for each subprogram , I run the the main program first, then without running the machine I run the subprogram only to get the report so literally I run the program four times . This might be the reason my average cut down dramatically... Link to comment https://qualityforum.zeiss.com/topic/17648-cycle-time-status-window/#findComment-98990 Share on other sites More sharing options...
[Me...] Posted September 28, 2019 Share Posted September 28, 2019 Please sign in to view this quote. Can u tell me How Come This ???? Link to comment https://qualityforum.zeiss.com/topic/17648-cycle-time-status-window/#findComment-98992 Share on other sites More sharing options...
