[SH...] Posted September 27, 2019 Share Posted September 27, 2019 The cycles time status Windows shows two times, one the actual time and other one I can't understand what is it. It is my setting time or something else , could you help me???IMG20190926081646.jpg Link to comment Share on other sites More sharing options...
[Da...] Posted September 27, 2019 Share Posted September 27, 2019 Upper should be "last run" and lower average from all runs (of this measurement plan?) Link to comment Share on other sites More sharing options...
[SH...] Posted September 27, 2019 Author Share Posted September 27, 2019 Please sign in to view this quote. usually I run this program around 35 minutes but the average value shows 7 minutes, difficult to digest..... Link to comment Share on other sites More sharing options...
[De...] Posted September 27, 2019 Share Posted September 27, 2019 Most likely this is either due to re-running the points, or re-running only a portion of the program which effectively adds a run with a close to zero run time. This throws off the average. I have not used it but I suspect this is what the checkbox is for which says "Do not record". If you check that it will likely not include the result into the overall result. Personally I just wish I could make that window go away and never come back, it is always wrong and it is frequently popping on screen over top of something I actually care about. Link to comment Share on other sites More sharing options...
[Ia...] Posted September 27, 2019 Share Posted September 27, 2019 Please sign in to view this quote. Preach. Link to comment Share on other sites More sharing options...
[SH...] Posted September 27, 2019 Author Share Posted September 27, 2019 Please sign in to view this quote. I got the point now, actually I have a long program, inside that I have three subprogram (one for true position, linear dimension and maching only). My customer asks me separate report for each subprogram , I run the the main program first, then without running the machine I run the subprogram only to get the report so literally I run the program four times . This might be the reason my average cut down dramatically... Link to comment Share on other sites More sharing options...
[Me...] Posted September 28, 2019 Share Posted September 28, 2019 Please sign in to view this quote. Can u tell me How Come This ???? Link to comment Share on other sites More sharing options...
