Upgrade
So I upgraded to the 2019 version.
In the past after an UG, when I started a program I had a box that popped up and told me my pdf save paths needed to be changed in order to go to the new folder in the new version. Well in this version I do not see that pop up.
Is there a way to make it pop up when I start each prg as before? Can it be done globally (doubtful)
See Pic ??
https://qualityforum.zeiss.com/topic/17684-upgrade/
Mike,
Do you create these paths each time you create a program? Because you can create the paths for all measurement plans and when you create a new program you select Name Setting for All Measurement Plans. When you upgrade the file folder will change or at the least you just change it in one place.
Mark
https://qualityforum.zeiss.com/topic/17684-upgrade/#findComment-99226
