[Mi...] Posted September 24, 2019 Share Posted September 24, 2019 So I upgraded to the 2019 version. In the past after an UG, when I started a program I had a box that popped up and told me my pdf save paths needed to be changed in order to go to the new folder in the new version. Well in this version I do not see that pop up. Is there a way to make it pop up when I start each prg as before? Can it be done globally (doubtful) See Pic ?? Link to comment Share on other sites More sharing options...
[Ma...] Posted September 25, 2019 Share Posted September 25, 2019 Mike, Do you create these paths each time you create a program? Because you can create the paths for all measurement plans and when you create a new program you select Name Setting for All Measurement Plans. When you upgrade the file folder will change or at the least you just change it in one place. Mark Link to comment Share on other sites More sharing options...
[Mi...] Posted September 25, 2019 Author Share Posted September 25, 2019 Yes I creat these paths as I write the prg's. I have this for 99.9% of my prgs so that they save in there respective folders Link to comment Share on other sites More sharing options...
[Ri...] Posted September 25, 2019 Share Posted September 25, 2019 Is any of the information stored in the header information to help store the parts? Calypso will automatically make folders/sub-folders for you, so you can setup your default path to read the header information of the program, and have it stored based upon that. Link to comment Share on other sites More sharing options...
