EVALUATION AND FILTERS FOR FUNCTIONAL CHECK HELP
when scanning a hydraulic cylinder that will be holding a large amount of pressure using rubber seals what would help with the best functional check, maximum inscribed, circumscribed, or LSQ ? The particular cylinder I am scanning has a diameter of 1.125 inches with a depth of 5.5 inches
max inscribed results for cylinder diameter 1.12335
LSQ resultsfor cylinder diameter: 1.12524
max circumscribed results for cylinder diameter : 1.1261
