Is It Possible To..........
If you go to the folder of the program in there should be a file called version. I can't believe this works but I just open the file in notepad and change the version and it will work. I've done this quite a bit and have not had any issues yet, you are going to want to know the version and type it in exactly. If you have a program in that version you can look at that file but its literally just a file that has nothing but the version number.
Just to add I have never had to go below version 6.2 so I have no idea what might happen past that. I doubt you can do this with anything before 6.
https://qualityforum.zeiss.com/topic/17694-is-it-possible-to/#findComment-99268
