[Ün...] Posted September 19, 2019 Share Posted September 19, 2019 Hello everyone, I am new to profil measurement and i would like to ask you how to manage succesfully measurment of profile characteristic shown in attached drawing detail. Link to comment https://qualityforum.zeiss.com/topic/17700-345000-calypso-help-for-profile-measurement/ Share on other sites More sharing options...
[Cl...] Posted September 19, 2019 Share Posted September 19, 2019 The View Z Ref dia (72) is actually a basic dim. I'd create a theoretical 72 dia circle, probe each 8 deg plane, intersect each plane with the 72 circle for two pierce points. Would you then apply a ± .0085 (.017) for the 9.35 basic? Not sure? Link to comment https://qualityforum.zeiss.com/topic/17700-345000-calypso-help-for-profile-measurement/#findComment-99308 Share on other sites More sharing options...
[Ch...] Posted September 19, 2019 Share Posted September 19, 2019 Looks like you have it right except your DRF, the spatial datum should probably be -A-. -C- is questionable whether it is one slot, or both slots at 180° to establish CL. Other than, you can scan each side of the slot, with proper filtering/outliers, should be fairly straightforward. Can you show us one of the basic slot features, its nominal position and form error ? Link to comment https://qualityforum.zeiss.com/topic/17700-345000-calypso-help-for-profile-measurement/#findComment-99310 Share on other sites More sharing options...
[Ün...] Posted September 20, 2019 Author Share Posted September 20, 2019 Thank you for your support, Christopher, I make reference C with two slots (3d line15) I create the slot with two separate planes. Below you can see the data and filtering of the planes I created. Link to comment https://qualityforum.zeiss.com/topic/17700-345000-calypso-help-for-profile-measurement/#findComment-99312 Share on other sites More sharing options...
[Ün...] Posted September 20, 2019 Author Share Posted September 20, 2019 Please sign in to view this quote. Thanks for your support clarke, I have created a theoretical diameter of diameter 72. Then I bought the right and left plane in the channel. I intersect them with the theoretical diameter, and here I question the distance of 9.35 mm. No problem at distance. But why are profile sizes so high when nominals and form errors appear appropriate? Link to comment https://qualityforum.zeiss.com/topic/17700-345000-calypso-help-for-profile-measurement/#findComment-99314 Share on other sites More sharing options...
[Ün...] Posted September 20, 2019 Author Share Posted September 20, 2019 Please sign in to view this quote. Thank you for your support, Christopher, I make reference C with two slots (3d line15) I create the slot with two separate planes. Below you can see the data and filtering of the planes I created. RESIM8.PNGRESIM7.PNGRESIM6.PNGRESIM5.PNG Link to comment https://qualityforum.zeiss.com/topic/17700-345000-calypso-help-for-profile-measurement/#findComment-99316 Share on other sites More sharing options...
[Ch...] Posted September 23, 2019 Share Posted September 23, 2019 Unal, The scan data looks really good, form error looks reasonable too. Only suggestion I might have, which is a personal preference, is to follow cookbook settings, and perhaps remove 5 additional points adjacent to outlier. Since the form is good, this is where profile/freeform surfaces get complicated, the machinist will ask: Where is it out, what adjustment do I make? You could start there, I might start with the indexing/angular variation, perhaps an "angle between features", as well as slot width... Other suggestion might be : It looks like your DRF/Secondary alignment is accurate, but you might choose datums inside the Profile Char. instead to let Calypso build the DRF and compare results. ( this doesn't always work out as expected; and you need 3 datums for profile). There are a variety of ways to establish the -C- datum I think, you could experiment there, and see if you can get Engineering's input. As Clarke mentioned above you can report the Chordal distance, using a .len(length) of a 3d line of the 2 constructed points. You can alos report what the actual 8° are to begin researching... Good luck ! Link to comment https://qualityforum.zeiss.com/topic/17700-345000-calypso-help-for-profile-measurement/#findComment-99318 Share on other sites More sharing options...
