[Ün...] Posted September 19, 2019 Share Posted September 19, 2019 Hello everyone, I am new to profil measurement and i would like to ask you how to manage succesfully measurment of profile characteristic shown in attached drawing detail. Link to comment Share on other sites More sharing options...
[Cl...] Posted September 19, 2019 Share Posted September 19, 2019 The View Z Ref dia (72) is actually a basic dim. I'd create a theoretical 72 dia circle, probe each 8 deg plane, intersect each plane with the 72 circle for two pierce points. Would you then apply a ± .0085 (.017) for the 9.35 basic? Not sure? Link to comment Share on other sites More sharing options...
[Ch...] Posted September 19, 2019 Share Posted September 19, 2019 Looks like you have it right except your DRF, the spatial datum should probably be -A-. -C- is questionable whether it is one slot, or both slots at 180° to establish CL. Other than, you can scan each side of the slot, with proper filtering/outliers, should be fairly straightforward. Can you show us one of the basic slot features, its nominal position and form error ? Link to comment Share on other sites More sharing options...
[Ün...] Posted September 20, 2019 Author Share Posted September 20, 2019 Thank you for your support, Christopher, I make reference C with two slots (3d line15) I create the slot with two separate planes. Below you can see the data and filtering of the planes I created. Link to comment Share on other sites More sharing options...
[Ün...] Posted September 20, 2019 Author Share Posted September 20, 2019 Please sign in to view this quote. Thanks for your support clarke, I have created a theoretical diameter of diameter 72. Then I bought the right and left plane in the channel. I intersect them with the theoretical diameter, and here I question the distance of 9.35 mm. No problem at distance. But why are profile sizes so high when nominals and form errors appear appropriate? Link to comment Share on other sites More sharing options...
[Ün...] Posted September 20, 2019 Author Share Posted September 20, 2019 Please sign in to view this quote. Thank you for your support, Christopher, I make reference C with two slots (3d line15) I create the slot with two separate planes. Below you can see the data and filtering of the planes I created. RESIM8.PNGRESIM7.PNGRESIM6.PNGRESIM5.PNG Link to comment Share on other sites More sharing options...
[Ch...] Posted September 23, 2019 Share Posted September 23, 2019 Unal, The scan data looks really good, form error looks reasonable too. Only suggestion I might have, which is a personal preference, is to follow cookbook settings, and perhaps remove 5 additional points adjacent to outlier. Since the form is good, this is where profile/freeform surfaces get complicated, the machinist will ask: Where is it out, what adjustment do I make? You could start there, I might start with the indexing/angular variation, perhaps an "angle between features", as well as slot width... Other suggestion might be : It looks like your DRF/Secondary alignment is accurate, but you might choose datums inside the Profile Char. instead to let Calypso build the DRF and compare results. ( this doesn't always work out as expected; and you need 3 datums for profile). There are a variety of ways to establish the -C- datum I think, you could experiment there, and see if you can get Engineering's input. As Clarke mentioned above you can report the Chordal distance, using a .len(length) of a 3d line of the 2 constructed points. You can alos report what the actual 8° are to begin researching... Good luck ! Link to comment Share on other sites More sharing options...
