PCM training
Ask them why the (shallow) equality boolean return is behaving diffrently then inequality. I would love to here their explanation. And don't settle for a "don't know". You paid to get answers!
Don't forget to report back, I bet this will be priceless ๐Ÿ˜ƒ
Explanation of what Im saying:
(Highlight and compute one at a time. )
"one" == "one"
"one" <> "one"
Oh, this is a good one also. Force them to explain this:
test=1101000110100010010010011001010001001000100011001
message(test)
https://qualityforum.zeiss.com/topic/17708-pcm-training/#findComment-99340
Good luck.
I took my PCM training probably 4 years ago and we basically spent a day writing a little bit of code to log the elapsed time that a program runs and saves (append) it to a text file. That was about a year before "measurement Duration" became a thing, so now i have all my programs fit with several lines of code in the presettings & post settings that could be replaced with a single command if i ever wanted to take the time to edit everything.
Then we spent 2 days on "parafiles" which can be very handy for part family programming because you can enter "Variables" into a text file that the program will read when you start a program, and adjust your nominals or tolerances or pretty much anything at all.
so you'll get a text box that says "what part are you running" and you click on "Part1 Part2 Part3" and depending on what part you click the program will read the parafile for that part and adjust your nominals and go.
I would say that PCM is probably the class that i got the most out of. I thought Basic & Advanced were very lacking in that i don't think anyone who's completely new to the Zeiss world can take those classes and be considered a programmer of anything more advanced than a washer. Curve and FF similarly left me with more questions than answers.
So you wont know what questions to ask until about a month after you're done with the class and your boss says "I need you to make 1 program that will measure every part we make", but then you'll just come to the forum and thats where youll get the most help.
https://qualityforum.zeiss.com/topic/17708-pcm-training/#findComment-99344
I have to admit that I'm a little intimidated by this. There will be high expectations put on me when I get back. We have taken over a huge transfer job from one of our other plants. This involves many part families, so yes, we need one base program to be used for multiple sizes. Hopefully, my previous career didn't give me too much brain damage, from all the shot's to my head.
https://qualityforum.zeiss.com/topic/17708-pcm-training/#findComment-99348
Ah, Artificial Intelligence.....
What they're trying to make us believe it is:
[img]https://i1.wp.com/925rebellion.com/wp-c ... =378%2C611[/img]
What it is to "them":
[img]https://i.pinimg.com/originals/d0/7e/44 ... 702959.png[/img]
What it really is:
[img]https://i.imgflip.com/2kcr9g.jpg[/img]
https://qualityforum.zeiss.com/topic/17708-pcm-training/#findComment-99350
"Hope the answers help clarify the questions"
Value_1 = "one"
Value_2 = "one"
if Value_1 == Value_2
message("Condition 1", ": ","equal")
endif
Value_1 = "one"
Value_2 = "two"
if Value_1 <> Value_2
message("Condition 2", ": ","unequal")
endif
"As String"
test = "1101000110100010010010011001010001001000100011001"
message(test)
"As decimal"
test = 1101000110100010010010011001010001001000100011001
message(test)
"PCM handles the parameter as decimal"
"Maximim decimal, value 1.1*10^16 internal"
test = 11010001101000100 //10010011001010001001000100011001
11010001101000099,4304 // output at nominal also wrong
"inside input"
11010001101000,000 // OK
message(test)
"decimal overflow"
test = 110100011010001001 //0010011001010001001000100011001
message(test)
"I think CALYPSO is still 32 and WINDOWS ifself are 64"
"Windows biggest"
"Windows crashes"
"Lichtjahr: 1 Lj = 9โ€ฏ460โ€ฏ730โ€ฏ472โ€ฏ580โ€ฏ800 m โ‰ˆ 9,5ยท10^12 km = 9,5 Billionen km"
"all systems are limited to -macro and micro-"
https://qualityforum.zeiss.com/topic/17708-pcm-training/#findComment-99352
Dear Klaus, you sort of missed the point with the bloolean. The question is why there is no return value to the user in the GUI.
Not how equality/inequality works.
The second is indeed precision issues, and 1.1*10^16 is correct.
These questions are not complicated, It's just fun to ask stuff that the tutors don't get asked very often I think.
Make 'em sweat a bit ๐Ÿ™‚
Ask them why quad-precision is handled in the same way as double. Eg:
123q5
123d5
https://qualityforum.zeiss.com/topic/17708-pcm-training/#findComment-99354
