[Cl...] Posted September 18, 2019 Share Posted September 18, 2019 I created a 2d curve to scan, when I created it, the vectors are not anywhere near normal enough to the surface for the stylus to make proper solid contact. I know how to change the vectors, but to what? If I do make the change, will it affect my results? Link to comment https://qualityforum.zeiss.com/topic/17736-2d-curve-vector/ Share on other sites More sharing options...
[Ch...] Posted September 18, 2019 Share Posted September 18, 2019 I'm pretty sure that changing the vectors will impact the probe radius correction and give you bad results. 3D curve won't work? Link to comment https://qualityforum.zeiss.com/topic/17736-2d-curve-vector/#findComment-99548 Share on other sites More sharing options...
[Cl...] Posted September 18, 2019 Author Share Posted September 18, 2019 Haven't tried a 3d curve yet. Link to comment https://qualityforum.zeiss.com/topic/17736-2d-curve-vector/#findComment-99550 Share on other sites More sharing options...
[De...] Posted September 18, 2019 Share Posted September 18, 2019 A 2d Curve is only intended for when all the normals share a common axis, for instance a line on a plane or a line that is a section around a cylindrical part. What you are showing is a curve on 3d geometry where the normals will all be different based on the directionality of the underlying surface. I am pretty sure you will need to use 3d curve here in order to generate nominals that have the correct orientation with regard to the underlying surface. Link to comment https://qualityforum.zeiss.com/topic/17736-2d-curve-vector/#findComment-99552 Share on other sites More sharing options...
[Cl...] Posted September 18, 2019 Author Share Posted September 18, 2019 Thanks Derek, 3d curve it is. Link to comment https://qualityforum.zeiss.com/topic/17736-2d-curve-vector/#findComment-99554 Share on other sites More sharing options...
