[Cl...] Posted September 12, 2019 Share Posted September 12, 2019 I am scanning several 2d curves, which run through a fillet. I don't want the points in the fillet to show up in my CAD evaluation. How do I mask them? Link to comment Share on other sites More sharing options...
[Mi...] Posted September 12, 2019 Share Posted September 12, 2019 Try the manual point masking under evaluations You can add in a start stop angle, OR my preferred way grab the axis and rotate them with the mouse. Create new circle segment upper left corner Link to comment Share on other sites More sharing options...
[Cl...] Posted September 12, 2019 Author Share Posted September 12, 2019 Thanks Mike, got it. Link to comment Share on other sites More sharing options...
[Br...] Posted September 12, 2019 Share Posted September 12, 2019 Open the feature window for the curve, select evaluations, then check the box that says "Nom. Vector Direction". Then select the parameters button next to it. This will give you a list of all the points within the curve. Whichever ones you select will be masked. Link to comment Share on other sites More sharing options...
[Cl...] Posted September 12, 2019 Author Share Posted September 12, 2019 Brett, I did as you instructed, and I can see the points being masked are highlighted, but my CAD evaluation still shows those points. Link to comment Share on other sites More sharing options...
[Br...] Posted September 12, 2019 Share Posted September 12, 2019 Please sign in to view this quote. That works for me. Not sure why you're still seeing those points in the eval. There must be more to the story. Link to comment Share on other sites More sharing options...
[Ma...] Posted September 13, 2019 Share Posted September 13, 2019 What Brett suggested works for me. Are you seeing the points? or a line that connects the actual points through the part that you masked? In other words, Calypso does not delete, or segment, the line that represents your measured curve scan. If you use Limit Evaluation then the points are masked but the line will now connect the new end point to the next start point but the points will be masked. Mark Link to comment Share on other sites More sharing options...
