[Ja...] Posted September 4, 2019 Share Posted September 4, 2019 Hello, It is being argued at my company that using a symmetry plane is not as accurate then using a symmetry point. Which is better or Right/Wrong? Thanks Link to comment https://qualityforum.zeiss.com/topic/17842-tp-of-slots/ Share on other sites More sharing options...
[Ri...] Posted September 4, 2019 Share Posted September 4, 2019 A lot of variables there. I would say that there is no true right/wrong answer here, but symmetry planes, like all 3d features require ample enough surface area to be constructed accurately and repeatably. Link to comment https://qualityforum.zeiss.com/topic/17842-tp-of-slots/#findComment-100162 Share on other sites More sharing options...
[sh...] Posted September 4, 2019 Share Posted September 4, 2019 One would assume if there is enough surface area to create planes that would be the most ideal and most accurate reading. If not enough surface area is available , one would be forced to create points instead. I personally believe using planes would be the best method. To only create points would be like not taking multiple points/scans for Ø's and only using the minimum of 3 points required to create a Ø instead. Link to comment https://qualityforum.zeiss.com/topic/17842-tp-of-slots/#findComment-100164 Share on other sites More sharing options...
[Am...] Posted September 4, 2019 Share Posted September 4, 2019 I have seen the plane method not work so well with small areas. If the surface isn't large enough any small deviations will shift the angle and that will be huge if the slot is located far from the datum. I just had this exact issue last week with a plastic material and small slots. Link to comment https://qualityforum.zeiss.com/topic/17842-tp-of-slots/#findComment-100166 Share on other sites More sharing options...
[Al...] Posted September 5, 2019 Share Posted September 5, 2019 Why not just use a Slot feature? Link to comment https://qualityforum.zeiss.com/topic/17842-tp-of-slots/#findComment-100168 Share on other sites More sharing options...
