Flatness between cylinder and plane
Hello German,
Are they only concern about the flatness of the plane at the cylinder? If so you could do a circle path strategy
of the plane around the hole. If they want to take into account the tilt of the axis of the cylinder, then
Calypso would want to use perpendicularity
Neil
I would do multiple strategies with the plane feature.
Do a circle path with the X,Y,Z coordinates and Diameter of the cylinder intersect. Then add a strategy for the rest of the plane.
Create a plane with feature point recall from that circle path intersect.
This will give you the flatness of that intersect area only.
