condition "selectCase"
Hello everybody,
I have a question about the condition "selectCase".
I would like to process the following procedure with the condition "selectCase".
Unfortunately it does not work. Is this even possible with "selectCase"?
The line "display ..." I would replace in the case of application, it is now only for testing.
NUT=0
OFFSET=0
inquireParameterList("NUT","V_NUT messen ?","OFFSET","OFFSET messen ?")
// Abfrage des gewählten Messplan
if (NUT==0 and OFFSET==0) then
display("MessPlan = "+0)
endif
if (NUT==0 and OFFSET==1) then
display("MessPlan = "+1)
endif
if (NUT==1 and OFFSET==0) then
display("MessPlan = "+2)
endif
if (NUT==1 and OFFSET==1) then
display("MessPlan = "+3)
endif
https://qualityforum.zeiss.com/topic/17994-condition-quotselectcasequot/
I have not been able to get select case to work, but with a little tweak your code works just the same. Try adding a closing bracket around each boolean test.
NUT=0
OFFSET=0
if (NUT==0) and (OFFSET==0)
endif
if (NUT==0) and (OFFSET==1) then
endif
if (NUT==1) and (OFFSET==0) then
endif
if (NUT==1) and (OFFSET==1) then
endif
selectCase works just fine, how ever, if you are making an comparison for equal, you need to add "is".
selectCase list(1, 2, 3, 4, 5).shuffle.first
case is == 1
   Syntax
case > 3
   Syntax
caseElse
   Syntax
endSelect
(With reservation for syntax error, sittning on a park bench and typing on my Phone.)
So you could use this in your case:
selectCase NUT.asString+OFFSET.asString
	case is == "00"
	case is == "01"
	case is == "10"
	caseElse
endSelect
