DURAMAX
Yes you can, and calibration will work the same as before you're just going to probe the stylus in the direction normal to the surface, you might also need to re-orient your reference sphere depending on how you set that up.
Thanks, it worked. 😃 😃 😃 😃
Just one more remark
Should I edit the window that appears with the angles?
