Default Tolerancing
in the Features menu, create a dim by clicking on one of the pre selected options. select "Last input" from the drop down menu and change your tolerances to what you want the rest to be. click ok and that number becomes the temporary default for the next dims you create for the day.
Now when you create a "Size>Distance" or "Size>Diameter" that tolerance will be filled in.
It won't help you out like Tom said, but i never knew about presets so this is the method that i've been using for 10 years.
https://qualityforum.zeiss.com/topic/18086-default-tolerancing/#findComment-101652
My directory is "C:\Users\Public\Documents\Zeiss\CALYPSO 6.4\data\toldat\" because I have multiple installations and I am using calypso 6.4, but yours may be different. To make sure, the easiest solution would be to search your C drive for a folder named toldat.
It is also possible that it is the file you were trying to use?
I have attached a zipped version of the file I created that should work, it works on my computer at least.
I put this file inside C:\Users\Public\Documents\Zeiss\CALYPSO 6.4\data\toldat\
And restarted Calypso and it now shows 'Decimal Place Tolerance' as one of the options in the drop down list.
The contents of the file are as follows.
<?xml version="1.0" ?>
<!DOCTYPE tolerancesDefinitionFile SYSTEM "tolerancesDefinitionFile.dtd">
<tolerancesDefinitionFile>
    <industrialNorm name = "Decimal Place Tolerance" group = "0" description =  "Decimal Place Tolerance" itemDescription =  "">
        <part No =  "1">
            <table No = "1" name =  "Default Tolerances" columnName =  "Nominal dimension range" description =  " + / - " itemDescription =  "">
                <row name =  "precision group " value =  "+/- 0.03">
                    <range start =  "0" stop= "9999" >
                        <value name =  "UT" value =  "0.762"/>
                        <value name =  "LT" value =  "-0.762"/>
                    </range>
                </row>
                <row name =  "precision group " value =  "+/- 0.01">
                        <value name =  "UT" value =  "0.254"/>
                        <value name =  "LT" value =  "-0.254"/>
                    </range>
                </row>
                <row name =  "precision group " value =  "+/- 0.005">
                        <value name =  "UT" value =  "0.127"/>
                        <value name =  "LT" value =  "-0.127"/>
                    </range>
                </row>
                <row name =  "precision group " value =  "+/- 0.001">
                        <value name =  "UT" value =  "0.0254"/>
                        <value name =  "LT" value =  "-0.0254"/>
                    </range>
                </row>
                <row name =  "precision group " value =  "+/- 0.0005">
                        <value name =  "UT" value =  "0.0127"/>
                        <value name =  "LT" value =  "-0.0127"/>
                    </range>
                </row>
            </table>
        </part>
    </industrialNorm>
</tolerancesDefinitionFile>
DecimalTols.zip
https://qualityforum.zeiss.com/topic/18086-default-tolerancing/#findComment-101672
