[Me...] Posted August 2, 2019 Share Posted August 2, 2019 I would like my default tolerances for characteristics to be: .001 .005 .010 How can I make this happen? Link to comment Share on other sites More sharing options...
[To...] Posted August 2, 2019 Share Posted August 2, 2019 In help, search Defining Custom Tolerance Tables Link to comment Share on other sites More sharing options...
[Ro...] Posted August 2, 2019 Share Posted August 2, 2019 in the Features menu, create a dim by clicking on one of the pre selected options. select "Last input" from the drop down menu and change your tolerances to what you want the rest to be. click ok and that number becomes the temporary default for the next dims you create for the day. Now when you create a "Size>Distance" or "Size>Diameter" that tolerance will be filled in. It won't help you out like Tom said, but i never knew about presets so this is the method that i've been using for 10 years. xfgdxfdbxfdb.JPGFetching info... Link to comment Share on other sites More sharing options...
[Br...] Posted August 2, 2019 Share Posted August 2, 2019 Please sign in to view this quote. I don't know if you can do exactly what you're talking about. What Tom mentioned I beleve only lets you select tolerances based on a range. (e.g. 0-18mm =±0.1, 18-30mm=±0.2 etc.) I think you want tolerances based on the decimal place. Link to comment Share on other sites More sharing options...
[Me...] Posted August 2, 2019 Author Share Posted August 2, 2019 Please sign in to view this quote. I tried doing that but I'm unsure where to place the .xml file...It says in those instructions to create that file in the 'data' folder but it didn't seem to work for me. I even restarted Calypso. Link to comment Share on other sites More sharing options...
[Ow...] Posted August 2, 2019 Share Posted August 2, 2019 It's a shot in the dark because I've never used it but, you might try down-loading the tolerance table maker in the excel tools at this link. Compliments of Calypso genius Ryan Stauffer. https://www.ellisontechnologies.com/zeiss-downloads Link to comment Share on other sites More sharing options...
[Me...] Posted August 5, 2019 Author Share Posted August 5, 2019 Please sign in to view this quote. Thanks for the tip Owen. Tried that method as well, it didn't seem to work. Nothing seems to show up in the drop down when switching tolerance methods...I am assuming it would show up under "User Defined Tolerance". Link to comment Share on other sites More sharing options...
[Me...] Posted August 5, 2019 Author Share Posted August 5, 2019 My .xml file is in Data/Toldat. Link to comment Share on other sites More sharing options...
[De...] Posted August 5, 2019 Share Posted August 5, 2019 These may help you find it.. if you are still trying to go that route. Version 5.4 (old style location) C:\Program Files (x86)\Zeiss\CALYPSO 5.4\opt\om\data\toldat Version 6.4 (newer style location) C:\Users\Public\Documents\Zeiss\CALYPSO 6.4\data\toldat Link to comment Share on other sites More sharing options...
[Me...] Posted August 5, 2019 Author Share Posted August 5, 2019 Please sign in to view this quote. I have the newer style, still not showing anything...It should show up in the drop down menu where the general tolerances and iso dimensions are, right? Link to comment Share on other sites More sharing options...
[De...] Posted August 5, 2019 Share Posted August 5, 2019 Once you have added your new file to that directory, Calypso needs to be restarted before it will 'see' the new file and offer it in the drip down list. Link to comment Share on other sites More sharing options...
[Me...] Posted August 5, 2019 Author Share Posted August 5, 2019 Yeah, definitely have tried restarting...still not working. Link to comment Share on other sites More sharing options...
[De...] Posted August 5, 2019 Share Posted August 5, 2019 My directory is "C:\Users\Public\Documents\Zeiss\CALYPSO 6.4\data\toldat\" because I have multiple installations and I am using calypso 6.4, but yours may be different. To make sure, the easiest solution would be to search your C drive for a folder named toldat. It is also possible that it is the file you were trying to use? I have attached a zipped version of the file I created that should work, it works on my computer at least. I put this file inside C:\Users\Public\Documents\Zeiss\CALYPSO 6.4\data\toldat\ And restarted Calypso and it now shows 'Decimal Place Tolerance' as one of the options in the drop down list. The contents of the file are as follows. <?xml version="1.0" ?> <!DOCTYPE tolerancesDefinitionFile SYSTEM "tolerancesDefinitionFile.dtd"> <tolerancesDefinitionFile> <industrialNorm name = "Decimal Place Tolerance" group = "0" description = "Decimal Place Tolerance" itemDescription = ""> <part No = "1"> <table No = "1" name = "Default Tolerances" columnName = "Nominal dimension range" description = " + / - " itemDescription = ""> <row name = "precision group " value = "+/- 0.03"> <range start = "0" stop= "9999" > <value name = "UT" value = "0.762"/> <value name = "LT" value = "-0.762"/> </range> </row> <row name = "precision group " value = "+/- 0.01"> <range start = "0" stop= "9999" > <value name = "UT" value = "0.254"/> <value name = "LT" value = "-0.254"/> </range> </row> <row name = "precision group " value = "+/- 0.005"> <range start = "0" stop= "9999" > <value name = "UT" value = "0.127"/> <value name = "LT" value = "-0.127"/> </range> </row> <row name = "precision group " value = "+/- 0.001"> <range start = "0" stop= "9999" > <value name = "UT" value = "0.0254"/> <value name = "LT" value = "-0.0254"/> </range> </row> <row name = "precision group " value = "+/- 0.0005"> <range start = "0" stop= "9999" > <value name = "UT" value = "0.0127"/> <value name = "LT" value = "-0.0127"/> </range> </row> </table> </part> </industrialNorm> </tolerancesDefinitionFile> DecimalTols.zipFetching info... Link to comment Share on other sites More sharing options...
[Me...] Posted August 6, 2019 Author Share Posted August 6, 2019 It finally worked! Thanks Derek! Link to comment Share on other sites More sharing options...
