Circle on a cone
What am I doing wrong ?? If i program a CC to known diameter sizes and lengths and correct cone angle the nominal line shows up in the correct location. So then I run the program and the actual points are all way off location and diameter.
I used cone calc to find the diam and location for the CC!! But it won't go there... 😕
https://qualityforum.zeiss.com/topic/18134-circle-on-a-cone/
I've done it both ways and then some other ways. The problem is that I can write the program from scratch, with no model at all, and the nominal line will not be in the right place. I can also touch off on a part and the same thing happens. I guess the thing that pisses me off most, is writing the nominal position and size , and having it locate in the wrong place. I mean , I wrote it into the correct location !!! 😭
https://qualityforum.zeiss.com/topic/18134-circle-on-a-cone/#findComment-102060
