[No...] Posted July 17, 2019 Share Posted July 17, 2019 Run the following code: string1=qm() display(string1) string2=qm()+qm() display(string2) string3=qm()+qm()+qm() display(string3) The last display() command throws an error. Why? Link to comment https://qualityforum.zeiss.com/topic/18184-why-does-this-happen/ Share on other sites More sharing options...
[Ri...] Posted July 17, 2019 Share Posted July 17, 2019 I'm a PCM noob, but when I compute the parameter, I just get "Nil". Link to comment https://qualityforum.zeiss.com/topic/18184-why-does-this-happen/#findComment-102300 Share on other sites More sharing options...
[Is...] Posted July 18, 2019 Share Posted July 18, 2019 no problems, with Calypso 6.6.20 Link to comment https://qualityforum.zeiss.com/topic/18184-why-does-this-happen/#findComment-102302 Share on other sites More sharing options...
[No...] Posted July 18, 2019 Author Share Posted July 18, 2019 Strange. I was testing with 6.4.2002. Should this be THE bug that was fixed in 6.6? 😮 I'll try again with 6.6. Stand by..... Link to comment https://qualityforum.zeiss.com/topic/18184-why-does-this-happen/#findComment-102304 Share on other sites More sharing options...
[No...] Posted July 18, 2019 Author Share Posted July 18, 2019 Indeed, it was. Works like a charm in 6.6! The real problem behind this was to get Eric's PCM code from the thread "...save probe calibration report..." to work. It always failed when I tried to add double quotes to the output to write a proper CSV file. Maybe I should finally make the transition to Calypso 2018... 🙄 Link to comment https://qualityforum.zeiss.com/topic/18184-why-does-this-happen/#findComment-102306 Share on other sites More sharing options...
[Da...] Posted July 18, 2019 Share Posted July 18, 2019 Norbert, you also have 6.4.28 as an option. I'm not sure if it holds fixes though. Link to comment https://qualityforum.zeiss.com/topic/18184-why-does-this-happen/#findComment-102308 Share on other sites More sharing options...
[No...] Posted July 18, 2019 Author Share Posted July 18, 2019 I know, but I skipped this service pack intentionally because I'm planning on going to 2018 right away on all machines. But I have to rule out possible issues with 2018's new image processing on the O-Inspect first. Link to comment https://qualityforum.zeiss.com/topic/18184-why-does-this-happen/#findComment-102310 Share on other sites More sharing options...
[Ri...] Posted July 18, 2019 Share Posted July 18, 2019 Please sign in to view this quote. I haven't noticed any negative issues with the new image processing. I love the morphological filters, and the auto-focus is much better now. I just got my 2019 license(s) yesterday, so I can test out the new parallel processing on our O-Inspect. I'm excited for that. Link to comment https://qualityforum.zeiss.com/topic/18184-why-does-this-happen/#findComment-102312 Share on other sites More sharing options...
[No...] Posted July 19, 2019 Author Share Posted July 19, 2019 I had a few issues which were mostly resolved in the latest service pack (to be honest, it had probably nothing to do with the image processing itself, but started with the same SP). Unfortunately Zeiss also re-introduced an old issue, which is assigned autofocus not working with certain elements. Since I had trusted this one to be gone forever, I had continued using assigned autofous instead of just a Z formula. Now I have to check all programs (again) and put in formulas. 🙄 Link to comment https://qualityforum.zeiss.com/topic/18184-why-does-this-happen/#findComment-102314 Share on other sites More sharing options...
[Ri...] Posted July 19, 2019 Share Posted July 19, 2019 Yeah. I've had issues with that. The latest Service Pack of 2018 seems to address that. I believe it had to do with contrast errors. Some times I could just delete the auto focus point and try again. Link to comment https://qualityforum.zeiss.com/topic/18184-why-does-this-happen/#findComment-102316 Share on other sites More sharing options...
