Motor output stage not ready
It seems you have a supply issue. Somewhere or someone else in your building or room is using more air than your compressor can supply.
Or your compressor is failing. I believe the 5 bars is what is being supplied if that is dropping it has nothing to do with you CMM.
  • 4 months later...
