[Su...] Posted February 24, 2019 Share Posted February 24, 2019 Hello guys Does anyone have aware of this problem.while running the program this happens.4 TRAVEL COMMAND REJECTED, MOTOR OUTPUT STAGE NOT READY. like this message came and pressure was dropped.i don't know why this problem occurs. Link to comment Share on other sites More sharing options...
[Da...] Posted February 24, 2019 Share Posted February 24, 2019 Please sign in to view this quote. Because it has pressure sensor and needs enough pressure to operate. When you get your bar back at around 5, start your drives again with M button between joysticks and you are good to go again. Link to comment Share on other sites More sharing options...
[Su...] Posted February 24, 2019 Author Share Posted February 24, 2019 Please sign in to view this quote. But the problem was repeatedly came however I restart entire machine and air drier everything. Link to comment Share on other sites More sharing options...
[Me...] Posted February 25, 2019 Share Posted February 25, 2019 It seems you have a supply issue. Somewhere or someone else in your building or room is using more air than your compressor can supply. Or your compressor is failing. I believe the 5 bars is what is being supplied if that is dropping it has nothing to do with you CMM. Link to comment Share on other sites More sharing options...
[Ri...] Posted February 25, 2019 Share Posted February 25, 2019 Gremlins, man. In my old life I had an older Contura G2 that would do this whenever the controller would get too hot (usually from someone forgetting to change the air filters out). Link to comment Share on other sites More sharing options...
[Da...] Posted July 19, 2019 Share Posted July 19, 2019 Did you solved it? Link to comment Share on other sites More sharing options...
