Radius Measurement using a different centre from Alignment
Hi Guys,
I was hoping I could get some help with this measurement.
The R3.619 call out is using a different eccentric centre (y-0.3438).
My characteristic is giving me a diameter instead of radius, which is ok, I can deal with that, but it is basing the diameter on the centre of the base alignment.
Is there any way to offset this characteristic to the eccentric centre?
You could use the radius measurement characteristic, which outputs every single point of the selected feature as a radius. That output is based on the nominal center of the feature. If you want a single value, define a secondary alignment with the radius center as the origin, recall the diameter to the sec. alignment and evaluate the radius..
