Compact Printout info
I almost exclusively use the compact printout. I need to permanently
add the customer drawing rev in the report header. How do I do this?
I don't want the operators to enter it manually each time, I want it to
appear permanently and automatically.
Thanks,
If you go to "Resources > Design custom printout > Printout header compact printout", you can open and edit the header. I'm not sure in what version that this became available. If the "Printout header compact printout" is not available, go to "Resources > Design custom printout > Printout head..." and open and edit the cphead.gra file.
