[Pa...] Posted June 25, 2019 Share Posted June 25, 2019 Hello, I am fairly new to Calypso and programming (less than one year). I am having trouble explaining the PiWeb reports to my Engineers, especially true position and true position of a bore pattern. Any help with explaining this would be greatly appreciated. I have attached a copy of a report that I am trying to explain to my QE. There is a FCF call out for the pattern to ABC @ MMC within .060 and then a refinement to A @ MMC within .010.115310_Rev_I2019-6-216_21_19 Sample #42_59_20 PM.pdf Link to comment https://qualityforum.zeiss.com/topic/18346-help-with-tp-of-bore-pattern/ Share on other sites More sharing options...
[An...] Posted June 26, 2019 Share Posted June 26, 2019 See attached.Contribution_26_06_2019.xlsx Link to comment https://qualityforum.zeiss.com/topic/18346-help-with-tp-of-bore-pattern/#findComment-103180 Share on other sites More sharing options...
[Ma...] Posted June 26, 2019 Share Posted June 26, 2019 I think you're going to want to turn on Addition Position Result (Resources/ Characteristic Settings Editor/ Printout/ Additional Printout). This will report out the X, Y, Z values in addition to the true position report characteristic. This will help explain some of what you are seeing. Mark Link to comment https://qualityforum.zeiss.com/topic/18346-help-with-tp-of-bore-pattern/#findComment-103182 Share on other sites More sharing options...
