[La...] Posted June 17, 2019 Share Posted June 17, 2019 Duramax, when I run the part the printout don't match the last run in the program. actuals don't match Link to comment https://qualityforum.zeiss.com/topic/18372-printout-dont-match-last-run/ Share on other sites More sharing options...
[Ja...] Posted June 17, 2019 Share Posted June 17, 2019 If your base alignment is different than your Datum Reference Frame, the actual values will be different. I'm guessing the actuals in the program are relative to base alignment, and you have a Position or something that is locating the feature in another DRF. Is this the case? Link to comment https://qualityforum.zeiss.com/topic/18372-printout-dont-match-last-run/#findComment-103306 Share on other sites More sharing options...
[La...] Posted June 21, 2019 Author Share Posted June 21, 2019 Sorry little green, don't no what DRF is, only one alignment base alignment. Still don't no how the last run in the program can vary to the printout. That's were the data comes from. Never seen this before or notice this before. Also varying on runouts I think these are to each other no alignments. Link to comment https://qualityforum.zeiss.com/topic/18372-printout-dont-match-last-run/#findComment-103308 Share on other sites More sharing options...
