[Ri...] Posted June 20, 2019 Share Posted June 20, 2019 Calypso locked up/froze during a base alignment earlier and the PC had to be rebooted in order to get access back. Upon restart I was welcomed by this little message: The machine did not home position at startup either. (how do I manually send it home for that matter?) Anyone seen this one before? Link to comment https://qualityforum.zeiss.com/topic/18384-error-message-at-startup-control-not-know-to-sdo/ Share on other sites More sharing options...
[Ri...] Posted June 20, 2019 Share Posted June 20, 2019 Reboot both the Controller and PC again. Also make sure that the SQL Server Service is running. Link to comment https://qualityforum.zeiss.com/topic/18384-error-message-at-startup-control-not-know-to-sdo/#findComment-103344 Share on other sites More sharing options...
