Probing Point Calculations
You will probably have to recall each point from the Plane into individual Point features.
Point - Recall Feature Points - Right Click on the Plane - Add Range Limits - Click on the top right button "New Point" - Enter the corresponding Point #. - Repeat
Edit - Turn on Recalculate Nominal Geometry, but make sure you do not have any actual data in the Plane, so it will calculate correctly.
