[Me...] Posted June 14, 2019 Share Posted June 14, 2019 Hi all, I've searched and looked at the other threads on this topic but I'm still not quite there. I have 2 planes, A-B, that are parallel and offset from each other as co-datums. I tried offset plane. 3 points, edited the offsets to match the basic distance between, and then recalled feature points into one plane. The resulting A-B plane was created but the results don't make sense to me. The form is horrible and the Z location doesn't seem correct. What's the best way to go about doing this? Robert Link to comment Share on other sites More sharing options...
[Ri...] Posted June 14, 2019 Share Posted June 14, 2019 Every time that I am working with an Offset Plane as such, I'm using it as my Spatial Rotation, so you don't see these errors. What is your Base Alignment made up of? Link to comment Share on other sites More sharing options...
[Me...] Posted June 14, 2019 Author Share Posted June 14, 2019 Plane -A- is my spatial and Z location. I'm using 2 dowel holes as -B- and -C-. -B- is X&Y location, C is rotation, and using Special rotating by distances to align to the print. Link to comment Share on other sites More sharing options...
[Ri...] Posted June 14, 2019 Share Posted June 14, 2019 Instead of Offset Plane, use Plane with Offset. Then combine the un-offsetted plane with the offsetted plane for the combined Datum Plane. Link to comment Share on other sites More sharing options...
[Me...] Posted June 14, 2019 Author Share Posted June 14, 2019 That's the first thing I tried. You can't recall feature points from a theoretical feature. If I use just recall I get a plane with nominals that are all zeros and no actuals. Link to comment Share on other sites More sharing options...
[Ri...] Posted June 14, 2019 Share Posted June 14, 2019 I think your first approach was correct, but I'd swap it out for your Spatial Rotation & Z Origin. There is no way that the two are perfectly co-planar, so that is why you are seeing error. I see this a lot with parts that have Datum Target points at various Z heights. Link to comment Share on other sites More sharing options...
