[Fl...] Posted May 22, 2019 Share Posted May 22, 2019 Hello friends, I have urgently, if is possible the response about: I want to put this notation in the report (see attach. photos) ,in this mode? Can explain the step?xxc.png Link to comment https://qualityforum.zeiss.com/topic/18512-notation-in-the-report/ Share on other sites More sharing options...
[Fl...] Posted May 23, 2019 Author Share Posted May 23, 2019 IT IS impossible or nobody knows.??????????????? Link to comment https://qualityforum.zeiss.com/topic/18512-notation-in-the-report/#findComment-104140 Share on other sites More sharing options...
[Is...] Posted May 23, 2019 Share Posted May 23, 2019 Please sign in to view this quote. It's impossible 🙄 Link to comment https://qualityforum.zeiss.com/topic/18512-notation-in-the-report/#findComment-104142 Share on other sites More sharing options...
[Da...] Posted May 23, 2019 Share Posted May 23, 2019 I *think* it should be possible with PiWeb. I don't have knowledge how to do it though. Link to comment https://qualityforum.zeiss.com/topic/18512-notation-in-the-report/#findComment-104144 Share on other sites More sharing options...
[Fl...] Posted May 23, 2019 Author Share Posted May 23, 2019 thank you for answer,maybe are the users that know the step.... Link to comment https://qualityforum.zeiss.com/topic/18512-notation-in-the-report/#findComment-104146 Share on other sites More sharing options...
[Is...] Posted May 23, 2019 Share Posted May 23, 2019 not sure if I understood the question, maybe this could help: https://www.youtube.com/watch?v=djcScB5 ... aj&index=1 Link to comment https://qualityforum.zeiss.com/topic/18512-notation-in-the-report/#findComment-104148 Share on other sites More sharing options...
[Fl...] Posted May 23, 2019 Author Share Posted May 23, 2019 thank's for answer but my questions is if is possible to see in the measurment this notation (see attach)photos 2. now i see this notation (photos 1) and i want to change.....Capture.PNGxxc.png Link to comment https://qualityforum.zeiss.com/topic/18512-notation-in-the-report/#findComment-104150 Share on other sites More sharing options...
[Fl...] Posted May 23, 2019 Author Share Posted May 23, 2019 Thanks and i understand this with piweb ,but i don't have this options with the DATUM(true position or form who is in the photos in previous email. i want to see in the report this model ( trueposition I0.2I M I AIBICI ) in this mode.... . and also i want to chose the options with standard ASME Y 14.5 . Is possible????? Link to comment https://qualityforum.zeiss.com/topic/18512-notation-in-the-report/#findComment-104152 Share on other sites More sharing options...
[Is...] Posted May 23, 2019 Share Posted May 23, 2019 aaaa, the Datum... Then: No idea ❓ Link to comment https://qualityforum.zeiss.com/topic/18512-notation-in-the-report/#findComment-104154 Share on other sites More sharing options...
[Ro...] Posted May 24, 2019 Share Posted May 24, 2019 Its one of the things that PCD does very well and Calypso doesn't do at all, but i wish they did. In PCD you select features as your datums (A,B,C) and actually build a feature control frame with all modifyers & unequal distribution & MMC built right in. Then the feature control frame or stack of frames appears right on the report. I also like that in the report, the True Position "Target" icon is live and shows a point of deviation in whatever direction you are off. but to answer the question of the OP, i don't think you can add a FCF to the report in any meaningful way. Link to comment https://qualityforum.zeiss.com/topic/18512-notation-in-the-report/#findComment-104156 Share on other sites More sharing options...
[Fl...] Posted May 24, 2019 Author Share Posted May 24, 2019 thanks all for info Link to comment https://qualityforum.zeiss.com/topic/18512-notation-in-the-report/#findComment-104158 Share on other sites More sharing options...
[Fl...] Posted May 24, 2019 Author Share Posted May 24, 2019 and another questions : I want to put the 2d best fit alignment for linear profil(2D curve ,only form) but i search in Utilites and i have only: Alignment , 3DBest fit alignment, RPS alignment,p6 alignment,Geometry best fit......? Link to comment https://qualityforum.zeiss.com/topic/18512-notation-in-the-report/#findComment-104160 Share on other sites More sharing options...
[Kl...] Posted June 2, 2019 Share Posted June 2, 2019 You've to create 2 results - Lineform_ABC => form to DATUM ABC. Deviation according to LOCATION and FORM. - Lineform_BestFit => only form. LOCATION is gone by best fit. Standard Report isn't possible, you must create a customized plott. Look at post "Customized Plotts" CALYPSO 2018, Curve and PCM required. Link to comment https://qualityforum.zeiss.com/topic/18512-notation-in-the-report/#findComment-104162 Share on other sites More sharing options...
