RDS-CAA multi-stylus
I have a stylus system that consists of a 3mm x 50mm in the -Z position and a 3mm x 33mm in the -X position mounted on a star adapter plate.
I know how to qualify a single CAA stylus but have heard there are issues with the lateral position. I understand how to adjust the positions on the 2nd stylus but does anyone have any history they would like to share regarding a similar
https://qualityforum.zeiss.com/topic/18518-rds-caa-multi-stylus/
Good question Tom. I've been sort of wondering about this also. We had an "advisor" tell us we should be using an "L" probe in our RDS-CAA so we won't have to turn our head so much. WE were very skeptical about how turning an L probe in an RDS-CAA head would work so we haven't tried it. I can see a star probe with 2,3,4 and/or 5 positions but not using an L and turning it. Looking forward to reading some of the replies on this one.
https://qualityforum.zeiss.com/topic/18518-rds-caa-multi-stylus/#findComment-104180
I was actually able to create it and qualify both probes though some of the angle choices for stylus 2 seemed to be too close in location to be the most accurate, i.e. A30/B30, A60/B60 and A45/B45. However, I was able to add additional indexes to access a wider array of points, and was able to "disable" some of the less desirable ones. I was able to do a Full Qualification on the new configuration.
As far as a single horizontal stylus or "L" probe. I do agree an "L" or "upside-down L", even in a non-CAA config, could be more versatile than a full star probe especially if you need to get into tighter internal areas.
https://qualityforum.zeiss.com/topic/18518-rds-caa-multi-stylus/#findComment-104182
